Results 1 to 11 of 11
    Feb 2010
    Default problem coding Audi A4 2002 - ABS bosch 5.7
    I am not able to code the abs module of a Audi A4 2002 - ABS bosch 5.7 . It does not assume the codification number. I belive the problem is in the workShop code ( i already tried 00000 and 12345)
    Can anyone help?
    Feb 2018
    Importer Number 0? Give a number there, for example 5
    Feb 2018
    You have the correct security code?
    Feb 2010
    tried several values ​​always gave error.
    Aug 2015
    Latvia
    HI, You must calculate login code (see VCDS label file) , it depend by car construction.
    You must calculate codding too. Login, set coding and steering angle sensor calibration must be done by one ignition switching on.
    All needed info is in Ross-tech Wiki .
    kiszka's Avatar
    Aug 2009
    Quote Originally Posted by fcarocha View Post
    if you can't handle it, I'll help you online
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
    Dec 2014
    PL
    Can anyone help?
    Try this.
    http://wiki.ross-tech.com/wiki/index...ics_(Bosch_5.7)
    Jun 2010
    I also tried coding bosch 5.7 with vcds in audi a6 2002.. For The First time i've put login, coding and wsc and that's all. In next ignition cycle abs module lost coding again.
    I did coding again and ALSO align g85.
    After these steps abs module remember the coding...
    Strange but real... i'm having these situations only with these abs 5.7 models.
    Aug 2015
    Latvia
    Already in 5th post I said the whole procedure (login, coding and steering angle calibration) must be done in one ignition on cycle!
    Feb 2010
    Car in Audi... Ok
  11. #11
    Jan 2010
    Need to enter correct login code to make any changes. Once login is accepted you cant back out of controller,make changes, save. Then back out.
