pin from ori: R05P
test this virgin
Hi all,
I need virgin bsi to adapt via obd with PP2000. The car crash and not start, failure in BSI. I read original eeprom 95160 and compare with donor bsi and this seem like lost data. with original BSI windows and door dont work and not start. with donor all work less start (normal with another pincode and keys). I need virgin donor BSI for adapt. Here both files. I read pincode from original BSI. is R05P but i dont know if it can be corrupted.
pin from ori: R05P
test this virgin
need help
now my goal is to buy xp-005
who will help?
carsandkeys (19th October, 2020)
it is from donor..................
edited: write then report ---- ok it easy answer before try - lazy man
need help
who will help?
as you said - my dump not work - fill whole dump FFFFFFF
need help
who will help?
I write donor original file, change vin and learn new keys. in engine ecu change Pin via dump. No DTC but show calculator blocked. its possible immooff in ecu or sincro with the scrap bsi file?
ME.7.4.4 0 261 206 943 96 503 461 80
in ME.7.4.4 if need off - post also flash
need help
who will help?
here.........................
need help
who will help?
rafal (19th October, 2020)
that's good info..................
need help
who will help?
