Thermo fan not working or no gas in the system.
Check schrader valves in service ports for gas.
Do 'actuator test' on engine cooling fan.
Any idea ?
If helped +Thanks & +Reputation
if there is low refrigerant pressure, compressor needs to be de-cluched so it does not any work to prevent damage to compressor because it gets lubricated with oil dispersed in refrigerant.. not enough oil leads to excessive wear.. you got the clue.
