Results 1 to 5 of 5
    tamer1024's Avatar
    Jun 2016
    Egypt
    Default Peugeot 301 Air conditioning problem
    Hi All,
    Hope all is well.
    I've a trouble in Peugeot 301 2020 Air conditioning system , the engine ecu request declutch the compressor as soon as engine starts.
    Could anyone help ?
    If helped +Thanks & +Reputation
    Oct 2020
    Thermo fan not working or no gas in the system.
    Check schrader valves in service ports for gas.
    Do 'actuator test' on engine cooling fan.
    tamer1024's Avatar
    Jun 2016
    Egypt
    Quote Originally Posted by ozvr View Post
    Don't know what you mean by gas
    and cooling fan 2 speeds ok
    tamer1024's Avatar
    Jun 2016
    Egypt
    Any idea ?
    br556hre's Avatar
    Mar 2010
    if there is low refrigerant pressure, compressor needs to be de-cluched so it does not any work to prevent damage to compressor because it gets lubricated with oil dispersed in refrigerant.. not enough oil leads to excessive wear.. you got the clue.
