Results 1 to 4 of 4
    Default speed limit vmax remove iveco edc17cv41
    Hi friends, is possible remove speed limit in an ecu edc17cv41 from iveco eurocargo? Now limit is 90kmh, is possible set at 110kmh?
    Hi friend, is possible help?
    pike's Avatar
    Sep 2013
    tacho present in car?
    Apr 2016
    Italy
    Hi ,
    Also I have same problem with Iveco Eurocargo 75-190 Eu 6 with speed limit fix to 90 Km/h , but I have solution for disable at all not for increase to certain value more ....
    This Eurocargo has Tacho and if you make speed lim off there are problem .
    Someone has tested solutions for increase only a little bit more without disable ?
    Thanks .
