use eeprom programmer
or mpps boot mode
or mpps boot mode
WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
Fileservice
no thanks no pass
There is VP on some pin of the OBD... think was 13, but not sure...
made my own wampyre device so im in mpps boot mode evry time flash is 256 on those cars and eprom only 48 maby the preflash chip is less than 256 so i need to flash eprom with moods ???
dos that sound waaaaayyyyyyy off or????
or maby i just cant find out to make antilag and NLS and Launch controll
and the worst part is i got a extra ecu "newer" but nomatter what i do i cant get it to stop activating the immobillizer same file stock and new ecu both...... new ecu activates immo
mate which ecu you got and what you want to do?
flash = tune, or eeprom mod ?
dennissharifi (22nd October, 2020)
Got and 06A 906 018CG
Its on a 2000 1.8t 150hp golf 4 GTI i want a file with antilag and Launch control ..... And immo off .....
Dont reallyd know i hav done 4 flashes All ok as internal flash but nothing shanges No antilag or LC so Guess ill give IT a go with a 256 KB file again with somone Else that made the chances maby om forgetting somthing
Nobody will give this file for free for ME3.8 with LC and ALS... its custom coding and in this forum maybe 2,3 persons which get solution for this.
Its possible to do ... but as told dont think anybody do it .
Immo off you need read 24c02.
For tune via flash... you need mpps + correct pinout and can be flashed (not read!) via bench pinout.
I have MPPS and corret pinout and ......
i made file myself
Iflashd it to car and viola it bangs like a mother~~~~er
Hi everyone have Hard cut solution.someone want try write me pm
