    Apr 2020
    Brazil
    Default steering angle hilux
    dear colleagues at Digita kaos, does anyone have a solution for this sensor?
    Apr 2020
    Brazil
    Default steering angle hilux 89245 0k020
    does anyone have a solution to this problem?
    Jun 2017
    Brazil
    To help you better by clearer information about what you need, like: Vehicle year and part number, and to post photos you don't need to compress winrar!
    Apr 2020
    Brazil
    ok Diogo Mello....it is a hilux year2019 steering angle sensor that is corrupted and causing failures.... processor R5F2154CEJFP84452...someome alread ten reading this processor?
    Jun 2017
    Brazil
    I took a similar case, I was only able to solve it by changing the sensor, I couldn't read the processor
    Apr 2020
    Brazil
    yes... here l also had to change the angle sensor...l tried to read the CG100.... but there was an error... you tried to read with which programmer?
