    Feb 2015
    Default Can anyone remove dpf from ecu on Chrysler 300c crd ?
    Can anyone delete dpf from my ecu file? I have tried but am no tuner, used a dpf remover program and car surges at low revs when pulling away so need help from someone smarter than me 😁
    Feb 2015
    Anyone able to help with this, I just need the file modifying for no dpf filter
    Dietrich's Avatar
    Oct 2017
    EUROPE
    post your file here
    Feb 2015
    Quote Originally Posted by Dietrich View Post
    post your file here
    here is the fie
    tank you
    Dietrich's Avatar
    Oct 2017
    EUROPE
    here you go
    pass in PM
  6. The Following User Says Thank You to Dietrich For This Useful Post:
    dexbethename (27th October, 2020)
    Feb 2015
    here you go
    pass in PM
    thank you so much I flashed it on and is running beautiful, if you fancy doing a stage 1 tune on it I wouldn’t complain
    but either way thank you so much
