    Default SifTeam-1.9.4C...19.01.2010
    SifTeam-1.9.4C-500plus-19-1-10-beta
    DB500PLUS:
    * Usable to flash
    * Enigma of: 19.01.2010
    OE Build Configuration:
    BB_VERSION = "1.6.2"
    OE_REVISION = "format_version "1"
    new_manifest [0000000000000000000000000000000000000004]
    old_revision [8384ee468ef9c285a8c9b35ef333e53be78b6445]"
    TARGET_ARCH = "powerpc"
    TARGET_OS = "linux"
    MACHINE = "dm500plus"
    DISTRO = "opendreambox"
    DISTRO_VERSION = "1.4.0"
    TARGET_FPU = "soft"
    [code]
    RapidShare: 1-CLICK Web hosting - Easy Filehosting]
    SifTeam-1.9.4C-500MV 19.01.2010
    1) Changed the CVS version 19.01.2010
    2) Change the file satellites.xml base (for problems with the satellite in motorized 28.2E)
    NOTES:
    For version ipbox-200 @ 64mb, you must:
    1) Install the image of the normal 200
    2) Install the file "serial_uboot_64.img"
    .. or both with Flashtools Flasher
    Programs:
    To start programs personal, valid for all images SifTeam: Add the desired command in / var/etc/rcS.d/S99user_start.sh bottom of the file (there are already 'present several examples ready to use, just uncomment it by removing the # symbol)
    Or create a script and put it in the directory:
    / var / etc / rcS.d
    As SXXnome_script.sh ..
    (Replace XX with a number between 80 and 99 depending on the priorities' desired)
    Tips:
    To enter the Control Panel if you are in the Control Panel Emu just press the yellow button, additional functions for use in WebIf.
    To open the menu 'script while you are in the Control Panel, simply press the 0 (zero).
    Errors
    If you found the error "curl_global_init .. .." with any plugin, after installing the same, just restart enigma or the decoder. (must read the new library is installed by the plugin)
    * The option Move OSD is not 'most' in this enigma
    http://jump.fm/RPHOT
    SifTeam-1.9.4C-5620MV 19.01.2010
    19/01/2010:
    SifTeam-1.9.4C-600pvr-19/1/10-Beta
    DB600PVR:
    * Usable to HDD or flash
    TARGET_OS = "linux"
    MACHINE = "dm600pvr"
    TARGET_FPU = "soft"
    http://rapidshare.com/files/337686690/SifTeam-1.9.4C-600pvr.nfi.zip
    New DDemon DM7000s - rev 15.01.2010
    Genuine image with the Last CVS
    Demonisat:-DDdemon_dm7000s_new revision_15/01/2010
    D?MoNiS@T D?V?LoP?R T?@M:
    Creator & Codes:- RoCKYDeViL
    Betatester 500/7000:- ANTRAG
    Skins Developer:- RRotan
    Pictures Developer:- SPIDERMAN97
    ---===ooo0ooo===---
    --with-webif=expert \
    --with-epg=private \
    --with-mhw-epg=yes \
    --with-flashtool=expert \
    --with-reiserfs=no \
    --with-ext-flashtool=yes \
    --with-enigma-debug=yes
    --with-pmt/tmp
    --with-New Start Enigma
    ---===ooo0ooo===---
    *****New!!!*****
    15/01/2010
    Emu: --CCcam 2.0.11 + Oscam--> inside!!! (start with image)
    15/01/2010
    New script init (special thanks for Antrag)
    ********end********
    14/11/2008/
    added new script plugins :
    (from the blue panel
    you choose--->
    "Addons"(script plugins renamed):
    ---> demonisatkeys_download
    ---> DDsoftcam_download (new 26/06/2009)
    ---> settings_Hotb (VHANNIBAl settings mono feed)
    ---> settings_Dual (VHANNIBAl settings hotbird/astra)
    ---> settings_Motor (VHANNIBAl settings multisat)
    ---> tool_ecm_info
    select the script you want and press the button "ok" of remote control.the download and the installation is very fast!!!
    when you download the settings after you press the button "ok" you wait a few seconds, the Dreambox will restart automatically in new settings
    you can add or remove scripts in "var/bin" if you have installed the image in flash or multiboot on dm7000 or in "usr/bin" if you have installed the image in multiboot on dm7020.
    Added new skin "skinbase by MX mod RGNMY"Many Thanks to Matrix and rrotan.
    20/02/2009:
    added new plugin "weekepg 3.2b_it" by MaxZ4 (Many thanks!!!)
    26/06/2009:
    added new plugin "DDsoftcam_download" - you download only a softcam!!!
    __________________________________________________ _______
    ***remember!!!***
    the folder for saving files of the plugin weekepg is set by default in the "hdd" directory.
    If you have not installed a hard disk you must change the path in the file "weekepg.cfg" and indicate the new path for usb pen or CF.
    for example:
    from
    OfflinePath=/hdd/weekepg/
    MaxDays=8
    OfflineLog=0
    DefLang=it
    to change in:
    OfflinePath=/var/mnt/usb/weekepg/
    MaxDays=8
    OfflineLog=0
    DefLang=it
    __________________________________________________ _________
    New pictures for Bild and Radio pictures by Spiderman97
    Compiled with Ubuntu 8.04 by RoCKYDeViL
    http://rapidshare.com/files/337339199/New_DDdemon_dm7000s.zip
    SifTeam-1.9.4C-7020-19-1-10 Beta
    SifTeam-1.9.4C-7020
    DB7020:
    * Usable to HDD, USB, CF or flash
    * OE Build Configuration:
    TARGET_OS = "linux"
    MACHINE = "dm7020"
    TARGET_FPU = "soft"
    http://rapidshare.com/files/337682014/SifTeam-1.9.4C-7020.nfi.zip
