Results 1 to 5 of 5
    Oct 2020
    Default bmw f 800 gs km on dashboard is blinking
    Hello guys!
    Im new on this forum and like to learn alot of the experts. I recently bought a bmw f 800 gs (2011) with a blinking km (37...) stand. Is there a way to stop this and can i without any experience do it by myself? and are there some tools i need?
    I hope someone can help me ore show me the direction i nee to go
    kind regards,
    Bas
  2. The Following User Says Thank You to derbibass For This Useful Post:
    chrisallen (27th October, 2020)
  3. #2
    Apr 2018
    EU
    Km in dash and ECU are not the same. Make ECU also or put in a can filter/blocker.
    If i helped you with your problem, please press the Thanks button.
    Ask your questions in the forum, no response on private messages.
  4. The Following User Says Thank You to Diagcar1 For This Useful Post:
  5. #3
    Oct 2020
    Quote Originally Posted by Diagcar1 View Post
    i understand dat ecu and dash are not the same, but as a noob i dont know how i can change this and wich tools do i need? is there somewhere step for step explanation on how to do that? and where can i buy the can filter/bloker?
  6. #4
    Mar 2019
    can filter/blocker what d u mean plz
    Sep 2020
    This is a CAN filter it allows you to change the mileage in the clocks and then the signal is blocked from your CAS unit /FEM unit, Otherwise the mileage will not stay it will revert to whatever is the highest stored value in the vehicle modules are, So if the CAS unit/FEM unit says 80k miles and you try to change the dash miles to 60K miles without a CAN filtter/ blocker then when you plug the clocks back into the car it will say 60k miles for 3 seconds and then it will jump back to the highest stored value in this case 80k miles, so to correct your problem you need to correct the mileage in the dash first then fit one of these CAN filters and then plug the clocks back in and your mileage will stay and not flash, Hope this helps
    https://www.auto-chips.com/can-filter-p1782.html
