Results 1 to 8 of 8
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Default Vectra c bcm reset correct procedure
    Please advice.
    Got vectra c 2.2 psg16
    After dead flat battery ,immo errors in cim and ecu.
    Man dtc i think is b3977-00
    What i found,that bcm data corrupted and need to be reset.
    found similar manual on corsa. All clear till keys reprogram. As in corsa manual there is option to erase and reprogram keus after bcm programming.
    Venctra not have this option in this window
    Photo vectra bcm window
    https://ibb.co/B30Bsn9
    Manual on corsa.
    https://blog.uobdii.com/how-does-opc...a-c-bcm-guide/
    So qyestion is.
    I do reset bcm ,reprogram back and vin. Than need go to cim and reprogram keys?
    Renault ECU tool / IO terminal / A.S.W
    Apr 2016
    uk
    There is no bcm on Vectra.
    I usually reset and program ECU and the car starts..
    Sent from my MI CC9 Pro Premium Edition using Tapatalk
  3. The Following User Says Thank You to comizelu For This Useful Post:
    drugowaz (24th October, 2020)
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Diagnostic show full scan ,and bcm present. I posted screenshot from car
    Theres no ecu here,all brain in injection pump
    Apr 2016
    uk
    Quote Originally Posted by drugowaz View Post
    Ecu psg16..
    I know,it's still ECU..
  6. The Following User Says Thank You to comizelu For This Useful Post:
  7. #5
    Aug 2019
    Bulgaria
  8. The Following User Says Thank You to miroopel For This Useful Post:
  9. #6
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Tried 5 tool, not posdible extract pin.
    Only 1 tool connects to all modules opcom.
    Something with CAN bad maybe
  10. #7
    Aug 2019
    Bulgaria
    Carprog and Abrites read the pin code in PSG16 via OBD.
  11. #8
    drugowaz's Avatar
    Mar 2015
    Lithuania
    I tried all,no tool read pin tried original tools
    I managed to start car without any programming. Its runs ok,no error in ecu ,only 1 error in cim
    Problem somwhere else b3977-00
    About psg not iddentified. But car runs. So dont know wheres problem
