Results 1 to 11 of 11
    May 2010
    Default peugeot partner 5ws40025d-t immo off
    hi all
    im need immo off in partner 2.0 hdi siemens driver 5ws40025d-t Sid 801
    how read end write this memory because this solution not work
    Just change like that:important in RED
    0 1 2 3 4 5 6 7 8 9 - A B C D E F
    0000:xx xx xx xx xx xx xx xx-xx xx FF FF FF FF FF FF
    0010:8F 01 00 00 07 00 02 0C-00 00 XX XX XX XX XX XX
    0040:XX XX XX XX XX XX XX XX-XX XX XX XX XX XX FF FF
    0050:FF FF FF FF 8F 01 OO OO-07 00 02 0C 00 00 XX XX
    this org bin
    please help
    rafal's Avatar
    Jul 2010
    UK - PL
    what are you used to read?
    your files are bad............
    need help
    now my goal is to buy xp-005
    who will help?
    Jan 2014
    Default immo off
    try and report,
    file for you 100% working
    pass in pm.
    May 2010
    use willem, read 8bit ok, 16bit not sure
    May 2010
    thanks for help but this file not work
    rafal's Avatar
    Jul 2010
    UK - PL
    Quote Originally Posted by kamionk View Post
    are you sure that problem is with immo?
    need help
    who will help?
    May 2010
    yes because orygynale file work , only somtime keys loose immo end light
    rafal's Avatar
    Jul 2010
    UK - PL
    try this one
    if will not work , change programmer and read again
    need help
    who will help?
    May 2010
    ok
    this file start only need key with immo, im think if all file its vergin end total immo its imposible, meybe need change flash?
    Aug 2012
    Hello everyone, I have this very same ECU, and I burned up the 93c56 Eeprom, don't have a previous back up, its there an file to program
    an empty Eeprom to make it work, is any of the above suitable??
  11. #11
    Aug 2012
    Anyone has the password for the files above to test them, please.
