Results 1 to 7 of 7
    EU
    Default P 407 BSI virgin 9655708380
    I need virgin for P407 2005 siemens bsi BSI-s02
    95128
    thank you
    EU
    hi
    can anyone help with this file?
    regards
    br556hre's Avatar
    Best is to use pp2000 to code it to fit all specs depending on equipment availability in your particular car.
    IMHO you can’t just delete content of 95128, perhaps some parts but vin number and pin to ecu needs to remain so you can use the Peugeot tools to code it properly.
    Rgds!
    Jun 2019
    slovakia
    virgin.rar try ti solution
  5. The Following User Says Thank You to kamil1234 For This Useful Post:
    davorOS (27th October, 2020)
    EU
    hi
    not work
    with this file I don't have ignition on,when I write old file I have ignition
    regards
    With the virgin file, did you try proceeding with BSI replacement ? This BSI behaves differently to others.
    EU
    hi
    yes but I don't have connection with BSI now
    when I first connect BSI I had ignition ON and could connect to car but car not start as not coded,now with virgin I can't connect to car
