Results 1 to 10 of 10
    Feb 2018
    Default Dash A3 8P change milage from eeprom
    To change the milage in dash a3 8p 2009, micronas dump are needed or eeprom is enough?
    BR
    To change the mileage, micronas are needed or eeprom alone is enoughTo change the mileage, micronas are needed or eeprom alone is enough
    rafal's Avatar
    Jul 2010
    UK - PL
    obd job.................... use correct tool and will be fine
    need help
    now my goal is to buy xp-005
    who will help?
    Feb 2018
    Ok, but I don't have an ODB tool. I want to do it on the table.
    BTW. What will be the cheapest OBD tool?
    Jan 2016
    xprog.....
    brend's Avatar
    Oct 2015
    Same where
    Sure..... for up more problem withx-prog.
    For what?
    1-2 min job obd2 away.
    Quote Originally Posted by qwert3433 View Post
    xprog.....
    NB!!! Don't ask in PM old file password , Im not remember.
    Feb 2018
    Then what do you recommend the cheapest tool to do this cluster via obd?
    galaxy0634's Avatar
    Jan 2018
    Namek planet
    Do you own vcds ?
    *I helped*push thanks button
    Feb 2018
    Quote Originally Posted by galaxy0634 View Post
    Do you own vcds ?
    Yes, I have VCDS
    galaxy0634's Avatar
    Jan 2018
    Namek planet
    Pm me i help you
    Mar 2017
    canada
    Smelecom ! Digiprog! Obdprog work great!!!!
