Yes the remote and transponder are separate.
Use vcds to check remote. If you get NOT OK the remote side has failed.
Probably the crystal.
Put new board from China key in or board from Audi A4 (which is the same)
drugowaz (26th October, 2020)
If you are going to add a new transponder don't use Audi A4. It uses a different algorithm you can kill the car.
I use ---avdi--seat exo
3R0837220 remote and id48-tp22 transponder key
for owner its needed to remote make work will try add just remote part.
manual procedure, the same as in the audi a4, you need two keys, one in the ignition and the other in the order from the driver
fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
