Results 1 to 15 of 15
    May 2011
    Default Renolink megane 3 key
    Hello people i want to ask you an question.
    Ive an Renault Megane 3 2012 and i want to know the correct procedure to program keys using renolink with an working key card and without working card.
    This is correct?
    1 - read pin
    2 - connect
    3 - start learning
    4 - put working card
    5 - learn key card
    6 - put new key card
    7 - learn key card
    8 - validate
    Or i need to click in test presence of card in any moment?
    This is my last key card and sometimes the car shows no key card recognized so im assuming the card will wont lasts longer
    Thanks all.
    Sep 2018
    Call for lockie if you want sleep well. Renolink is not trusted interface (many people had bad experiance with coding keys with it.
  3. The Following 2 Users Say Thank You to arosta For This Useful Post:
    extream87 (26th October, 2020), godfathertre (26th October, 2020)
    May 2011
    Yes ive read many people on forum saying got uch blank but others done the job....dunno
    If i try only:
    1 - read pin
    2 - connect
    3 - start learning
    5 - learn key card
    7 - learn key card
    8 - validate
    I take the risk of get uch erased?
  5. The Following User Says Thank You to extream87 For This Useful Post:
  6. #4
    Aug 2019
    Bucharest Romania
    Quote Originally Posted by extream87 View Post
    Yes ive read many people on forum saying got uch blank but others done the job....dunno [
    I think Megane 3 2012 with original UCH software it's safe. I had UCH blank after reading ISK and PIN on a Renault Master 2017 but UCH software was upgraded in 2019. But PIN was correct and I learnt again UCH + new key with existing key (containing ISK) and PIN read at the beginning. You must acces coresponding XML of the UCH.
    On the other hand Dacia models 2019 worked flawless (BCM T4).
    If i try only:
    1 - read pin
    2 - connect
    3 - start learning
    5 - learn key card
    7 - learn key card
    8 - validate
    It's correct. For cards i think you need to press "START" button between steps 4-5 and 6-7.
    IMHO no. In my case (Master 2017) UCH get erased when I attempted to read PIN but PIN was read correctly and I read it multiple times.
    But for Megane 3 2012 with original UCH software I think you won't have any problems with Renolink 1.87.
    scotland clydebank
    Renolink is not safe to use what kind of support will you get after messing up someone car call a Locksmith and dream happy or pay the price also the tool is not easy to use for the beginners so stay well away if you want something good buy Renault ecu tool stop playing with Renolink otherwise you will play the price.
  8. #6
    May 2011
    To stay safe its possible to dump uch?
  9. #7
    Sep 2019
    The safest thing you can do is either buy trucode, or cheaper again hire a local locksmith, the latter the better
  10. #8
    Nov 2020
    Did you manage to program a new key with renolink? Extream87
  11. #9
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    l did Megane 3 today , perfect 1.87
    only get keys from the Renault man on ebay , spot on there keys , keyless works fine too
    but l have just ordered renault tool as l hear its safer and l need for more ecu and uch cloning
  12. #10
    May 2011
    Gonna try tomorrow...
    Someone knows the difference between key in protect mode and card in protect mode?
    My key card is not smart i need to put it
  13. #11
    May 2011
    Made the new key without problems
    Thanks all
    Obs: ive choosed key protect mode
  14. #12
    Nov 2020
    Did you use this procedure below? Or is possible to program a new card without using your working card ?
    1 - read pin
    2 - connect
    3 - start learning
    5 - learn key card
    7 - learn key card
    8 - validate
  15. #13
    May 2011
    Answered all questions via pm.
    Happy chrismas guys
  16. The Following User Says Thank You to extream87 For This Useful Post:
    Mijecki (22nd February, 2021)
  17. #14
    dimet's Avatar
    MKD
    Happy chrismas guys
    I also want to know the coding procedure.
  18. #15
    Nov 2020
    I managed to read the card with Renolink. At first must you scan the car otherwise it will not copy. After the scan can you do the following steps: Choose extra in renolink/ keys/type uch and then:
    Read pin
    Connect
    Insert blank key (new one)
    Test presence
    Remove key
    Start learning
    Put again the blank key
    Learn key card
    Remove key
    Put the key you already have
    Learn key card
    Now you have 2 keys ids check the 2 checkboxs and click validate and disconnect and done
    I have one problem, I used a card from aliexpress. The card is not working properly with buttons. Do you a better supplier of cards ?
    I managed to read the card, but I had to scan the car before I could copy the key.
  19. The Following User Says Thank You to Adriaan For This Useful Post:
    turbocip (6th May, 2021)
