ArriusLion22 (28th October, 2020)
hello how are you
please i need help from experts in this kind of problems
i got a bmw f10 m5 with DKG transmission the car had 1 burned ecu i did not know the reason so the owner got a couple of ecus and 1 cas4 and a key
1st i had to synchro with the transmision and job done swapping isn from old ecu left
now my problem is 2 things
1- the kit that client got is a us m5 version with 315 mhz key and the car was 868mhz so remote is not working my question how would i solve this problem? is it possible swith frquency in cas dump or need coding ? what other solutions is possible please hellp!!!
2- the new kit had diffrent mileage approx 73898 the car had almost 43000 now i am having in dash a fault about vin number and in other modules error getting mileage from cluster , sometimes ignition on it appear with 999999 other times normal but with the famous DOT in middle , i tried inserting same milege in dash as cas but now 00000 so no more ideas i have please help!!!
thanks in advance for all
you need to change the VIN, either in cas to the cars VIN or the Dash to the VIN from cas.
ibratex (29th October, 2020)
And about the "315 mhz key and the car was 868mhz..."
There is no chance to switch frequency... it is about the hardware inside!
Sorry...
Better was to clone just this 1 burned ECU!
NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
If your PM box is full, clean it right now...
Otherwise, your requested file will be deleted... for ever!
For frequency problem you only replace key antenna with 315 mhz just it . Remote key will works. For red dot you can change vin number from cas4 orginal vin and change km from cas4 with original km and code to car all problem wil be solved
thanks alot for the ideas , i will test now and report ill change vin in cas to original vin and original mileage then code to car
about the 315 i will change antena , anyone know location ? ..
i did not clone because old cas someone messed up was unable to make it back to life again
cheers for now
ok a have news
first i changed vin in CAS to original vin and the famous DOT on dash desappeared and coded again
so i programmed a 868 mhz key and now central are working normally
BUt after coding in first step now i am having a huge problem i think
a fault in DME about power class
1F2108: dme- incorrect data record: power monitoring
i autel maxysis it says need dme reprogramming and coding so i did that also but fault stays and on screen says to drive moderatly
is this have a solution ? maybe also i have to change vin inside dme is that possible ? thanks again
here are the files of both dme and cas with this fault
i heard it might need reset working hours , how and can someone do it please
Sbaumil (12th June, 2022)
anyhelp please resettinng working hours !!
Did u resolve the problem?
