    Dec 2018
    Default VW GOLF 4 - disable alarm 1J0 959 799AH
    Hello guys,
    we can help me enybody, i need disable alarm in confort module vw G4 1J0 959 799AH, motorolla .
    Thanks werry much
    Why don't you try with VCDS?
    Dec 2018
    isnt possible with vcds
    Go 46-Central conv -> coding
    Aug 2018
    Not possible with vcds. No coding or adaptation value for that. Need to edit eeprom. Your config addresses are 4281, 4287, 4293 and 4285,4291,4297. I quess. First you should read eeprom from $1000 - $11F8. Download eeprom content with software from https://github.com/gmenounos/kw1281t...tag/v0.20-beta. If it is standard alarm without irü or dwu, default values may be all 255. Maybe 16 to first 3 disables it. And 32 to 4285,4291,4297. I don't have my notes available just now. Will check later if i have something more information.
  6. The Following User Says Thank You to ziidii For This Useful Post:
    pokusmaster (12th November, 2020)
    Dec 2018
    Thanks, car is gone, i unplug a few wires from unit, and all is ok, thanks for help .
