Results 1 to 14 of 14
    Nov 2016
    Default Orange5 Pcb Help
    Hi friends i need help about Orange5 pcb
    Today i used 12v adapter on Orange5
    a transistor burnd on pcb and dont know if transistor or differnt
    Anyone have picture or what is this item???
    Thx....
    Aug 2019
    Bulgaria
  3. The Following 6 Users Say Thank You to miroopel For This Useful Post:
    danielif (14th November, 2020), k1champion (29th November, 2020), mnem (29th October, 2020), PSAcars (30th November, 2020), Royalbej (29th October, 2020), Yhoni (22nd April, 2021)
    Nov 2016
    So thx friend for your help
  5. The Following User Says Thank You to Royalbej For This Useful Post:
    miroopel (29th October, 2020)
  6. #4
    Mar 2016
    i did the exact thing, the power port should be 12v since its the most common used for 12v in the automotive sector
    carradio2001's Avatar
    France
    I put LM7805 between input and 5v output, the reason is the same for what happened a few posts up and for what say henal
    BR,
    Carradio2001.
  8. #6
    sv2hqx's Avatar
    Jun 2014
    why all of you use 12v adaptor?
  9. #7
    Aug 2019
    Bulgaria
    All tools have a 12 volt adapter. It is easily confused
  10. #8
    sv2hqx's Avatar
    Jun 2014
    Quote Originally Posted by miroopel View Post
    yes but this port says 5VOLT !!!!!!!!!!
  11. The Following User Says Thank You to sv2hqx For This Useful Post:
    catalinosonesti (8th January, 2021)
  12. #9
    Aug 2019
    Bulgaria
    Most table adapters are 12 volts. You've never been wrong ?????? I do not want to argue. I tried to help. I'm leaving the topic.
    Best regards miroopel
  13. #10
    sv2hqx's Avatar
    Jun 2014
    yew i want to help too
    i feel sorry for this even if its a clone and cheap
    but its a eprom/mcu programmer and the max voltage is 5v
    anyway............
  14. #11
    Yhoni's Avatar
    Jun 2014
    Somewhere in time...
    I had the same problem and i used your solution 7805.
    Thank you.
    If my post has helped you, do not forget to click on the "THANKS" and "REPUTATION" button !!!
    I do not answer in private questions that can be solved in public.
  15. The Following User Says Thank You to Yhoni For This Useful Post:
    miroopel (22nd April, 2021)
  16. #12
    Sep 2015
    when use external adapter in orange 5???
  17. #13
    Yhoni's Avatar
    Jun 2014
    Quote Originally Posted by Holmae View Post
    I was just doing tests to read a 3K91D and since I was lacking VFP power I thought I should power the programmer and by mistake I plugged in the 12v one and burned that transistor.
    Now I have installed the 7805 and so I use the 12v power supply.
  18. #14
    Nov 2017
    Dobruja
    Haha! I did that too. And a friend of mine said the same: Didn't you see 5V written on the box?
    As you, my power source is 12V as a daily use.
    My Q2 is E5FAH that I blown.
  19. The Following User Says Thank You to volodin69 For This Useful Post:
    miroopel (14th September, 2021)
