ofcourse................just clone will never work on edc17............
need help
now my goal is to buy xp-005
who will help?
csigagti (1st November, 2020)
First restore data off the replacement ecu.
You need read the immo data from the old ecu, or cluster.
And adapt the eeprom data, of the replacement ecu.
Tango and vvdi2, some other tools, have a immo editor.
If your replacement ecu, is choosen correct.
Dsg or manual etc. Compare longcode.
Then this ECU can't be cloned?
Thanks!
The two ECUs are the same Bosch 0 281 018 498, 04L 907 309 D EDC17C64
but the original is the Skoda 184PS, the clone I wrote is the Seat 150PS
So I tried full ECU cloning with K-Tag, but unfortunately it doesn't work!
There was no problem reading the original ECU or writing the purchased ECU either!
When the Cloned ECU is installed, the glow lamp flashes during the test and the following DTCs are present when the fault is read P160A00, P157000
Adapt used ecu with odis online
with special fonction AVDI you can do it !
If you haven't , post your ori files and the second file " flash and eep for two".
