Results 1 to 4 of 4
    Jan 2010
    Default 2005 vw phaeton cluster swap
    Hey guys I have customer with 2005 phaeton cluster has failed. Backlight and lcd dead. He purchased used cluster. Will I be able to adapt used cluster using Odis or does it need to be virgin First?? IIRC RB8 cluster.
    Jan 2010
    Quote Originally Posted by carlosmen View Post
    You can do with ODIS online
    Will I be able to adjust mileage also or no??
    roth18's Avatar
    Dec 2009
    US
    Did you solve this??? I have similar issue.
    TY
    Best Regards, Roth.
    Jul 2016
    You should be able to adapt used cluster using ODIS S with Geko Login as long as VW did not start locking used module out in your country....and about mileage correction you need different tool to correct that if you want to
