Results 1 to 9 of 9
    Aug 2019
    Default EDC17C41 brick after write?
    Hello, yesterday I write a remap file with KTAG bootmode to EDC17C41 BMW F11 520d.
    After first file I had errors like in the attachment. ESP and TMPS did not work.
    I wanted to make a correction and after uploading the car does not start or communicate with any diagnostic interface.
    On the bench - bootmode,ecu normally communicates with KTAG.
    Baddog84's Avatar
    Sep 2012
    Germany
    ori or clone ktag?
    you can try this
    WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
    Fileservice
    no thanks no pass
    Aug 2019
    Quote Originally Posted by Baddog84 View Post
    ori or clone ktag?
    you can try this
    Clone tool 7.02 software 2.25
    You only change checksums?
    I write original file, car dont start
    ECU dead?
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Where did you connect to for boot points
    PelsonBMW's Avatar
    May 2020
    Eu
    sync CAS with DDE
    Aug 2019
    Quote Originally Posted by PelsonBMW View Post
    sync CAS with DDE
    What software i need?
    PelsonBMW's Avatar
    May 2020
    Eu
    Quote Originally Posted by labors View Post
    Ista D or Inpa
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    you damaged ecu when you opened
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
    Top Poster sonho1999's Avatar
    Portugal
    in my opinion you damaged the ecu by opening
