Results 1 to 15 of 16
    tfourk's Avatar
    Jan 2016
    Fort Lauderdale, FL
    Default 2019 Honda CRV Setting miles
    Are their any solder points? I'm asking because I don't want to unsolder the chip if possible. Which I gather is the 8 legger to the upper left of the big chip. My other problem is that my smelecom pogo doesn't fit the chip. I'm including some pictures of the back of the board and I'm hoping some of you can give me some guidance. Thanks in advance to all that participate. I believe it's a 93C86.
    2020-11-04 10.47.19.jpg2020-11-04 10.47.25.jpg2020-11-04 10.47.43.jpg2020-11-04 10.47.59.jpg2020-11-04 10.48.22.jpg
    Apr 2018
    EU
    Take out your multimeter and find the points.
    It's easy to find.
    If i helped you with your problem, please press the Thanks button.
    Ask your questions in the forum, no response on private messages.
  3. The Following 2 Users Say Thank You to Diagcar1 For This Useful Post:
    GameTheoryOptimal (5th November, 2020), tfourk (9th November, 2020)
    May 2015
    Here the pinout. If help thank’s and rep please.
  5. The Following 2 Users Say Thank You to Berubeg For This Useful Post:
    GameTheoryOptimal (5th November, 2020), tfourk (5th November, 2020)
  6. #4
    Ozmr97's Avatar
    Feb 2016
    NY
    CRV_2017_C76.jpghere is 2017 crv
  7. The Following 3 Users Say Thank You to Ozmr97 For This Useful Post:
    claudio35 (6th November, 2020), GameTheoryOptimal (5th November, 2020), tfourk (5th November, 2020)
  8. #5
    norbisko's Avatar
    In a House
    CAN YOU UPLOAD A BIGGER SIZE PICTURE ?
    THANKS
  9. #6
    Ozmr97's Avatar
    Feb 2016
    NY
    Untitled.jpgthis any better
  10. The Following User Says Thank You to Ozmr97 For This Useful Post:
    norbisko (6th November, 2020)
  11. #7
    FxShaw's Avatar
    Nov 2013
    Outta This World
    He has a different dash where tssop at the back those with the pinout posted if for different type.
    as Diagcar1 said...trace if you don't want to take out and read.
    🔥Wacka Wacka 🔥
  12. #8
    uk
    it depends on which programmer you are going to be using to read eeprom, not all programmers are safe to read incircuit,
    you can end up with corrupted data in eeprom, id unsolder and read unless your programmer is safe to read incircuit.
  13. The Following 2 Users Say Thank You to raf0468 For This Useful Post:
    jomberykaso (6th November, 2020), tfourk (9th November, 2020)
  14. #9
    norbisko's Avatar
    In a House
    Quote Originally Posted by raf0468 View Post
    DONT EVEN THINK ABOUT USING SMELECOM ! WILL CORRUPT 100%
  15. #10
    tfourk's Avatar
    Jan 2016
    Fort Lauderdale, FL
    Quote Originally Posted by norbisko View Post
    That's funny. I set it today using Smelecom DSP3+. Worked 100%! Thanks everyone for all the helps and guidance.
  16. #11
    norbisko's Avatar
    In a House
    Quote Originally Posted by tfourk View Post
    Failed every time for me, corrupting the dump. When doing in circuit
  17. #12
    May 2011
    hi
    with upa low voltage never had problem...always perfect
  18. The Following User Says Thank You to digimile For This Useful Post:
    norbisko (10th November, 2020)
  19. #13
    tfourk's Avatar
    Jan 2016
    Fort Lauderdale, FL
    Set voltage to 3.0 or 2.9. First try at 3.7 gave me an issue. These chips keep getting smaller so voltage drops on them as well for efficiency purposes/manufacture process changes, something to keep in mind.
  20. The Following User Says Thank You to tfourk For This Useful Post:
    neospeedo (11th November, 2020)
  21. #14
    norbisko's Avatar
    In a House
    Quote Originally Posted by digimile View Post
    hi
    This is how I get them done now. easy! No issues.
  22. #15
    tfourk's Avatar
    Jan 2016
    Fort Lauderdale, FL
    Restarting conversation just because another one came in... This one the display is flickering they said it's intermittent. Anyone have a power up for the 32 pin plug in the back of the cluster?
