I opened it very carefully and made sure to not break or damage anything.
Replacement ECU has SAME numbers on the case?
With new ECU does your diagnostics tool connect and read fault codes etc?
Eight bytes walk into a bar. The bartender asks, “Can I get you anything?”
“Yes,” reply the bytes. “Make us a double.”
Seems okay EEPROM inside WinOLS has same VIN number from READ.EPR and read 2 after writing org read.EPR
But eh CKS is different, try writing .EPR again.
Just to confirm, you wrote files like this...
READ.EPR---->EEPROM ST95320
READ.FLS---->EXTFLASH M58BW016DB (MAPS)
READ.MPC--->MICRO MPC563/MPC564
Also your plug in is P113 on KTAG?
If you accessed the BDM port by opening the ECU and removing PCB from aluminum side then i can congratulate you. You killed 2 ECU's!!!
P.S. And why did you even read BDM just to remove DPF? You could easily read and write the map part using k-line pin... Or maybe KTAG is the only tool you have?
Man 100% sure its a dead ECU.
Always do them using kess by connecting CAN directly.
Very bad idea to take PCB out, done it a dozen of times, But with Some really special techniques, main thing is to avoid bending the PCB, otherwise MCU deballs from the PCB. If you did it with screwdrivers and bensin PCB - Both are dead with 100% chance.
I repaired ECUs after unexperienced tuners - just needs a proper reballing and sometimes chips in the corner of the front side gets detached (in that case no BDM r/w)
Is it 100% the other ECU is dead? It reads and writes still, not like the first one who doesnt read or write anymore..
I had no idea that you could not open EDC16C31, I am used to opening ECUs and reading it normal.. Did not know these brick because of that..
Is there any other ECU type that you can not open?
I would like to know in advance
EDC16C31 Mercedes, EDC17CP45 BMW, MEVD172P BMW, MEVD1724 BMW, MEVD1729 BMW, MEVD172G BMW, MEVD1726 BMW VAG MED17.5, 17.5.25, 17.5.21 also same. If you need to lift board or drill something - always risk of damaging PCB/contaminating ECU with metal residuals.
P.S. I have never damaged Any of those, and I have opened all of them listed above for years before i got proper tools. You just need to use brain and search buttons. Do your homework in time to sleep well.
1st ECU is dead With no com to BDM Because of detached chip Legs in the cornee of the front side (i can make a photo tomorrow When i am at work)
2nd ECUs MCU is partially deballed from PCB, you can reball it and it will work.
sniegavirs (24th November, 2020)
did you tried to restore using the single file from bdm read , instead of write them separately one by one (fls , mpc , eep)?
