Results 1 to 15 of 16
    Default ASTRA 2006 INSTRUMENT CLUSTER
    can anyone help me with a pin out for a 2006 AH ASTRA for the instrument cluster it has one main plug on the rear of it i want to bench test it and power it up
    the reason being that some has being playing with the eprom and now the speedo is reading wrong so i need to fix it anyone got a good dump to compare or can at least tell me where i should look
    anyone ?????
    dashradio's Avatar
    Inafield
    Pin 21 is negative
    Pin 19 is positive
    Press trip button on the dash to activate screen
    uk
    dump from another vehicle is no good ,as the dash is coded to the car..........
    Timisoara-Romania
    You can put another dump , but you need to modify vin number in dump before programing eprom. Work 100%.
    If you don't know how to do , post vin of car and tel me if petrol or diesel and I wil send dump for your car.
    gee thanks for the reply's i don't' have the Vin number but i do have a dump does that help ?
    intact i have two dumps for this dash as i got a secondhand cluster from someone else and got a dump from that
    thanks Dashradio those pins work
    Timisoara-Romania
    Quote Originally Posted by rastus86 View Post
    Use good dump with your Vin number. You can see in picture location of Vin.
    Quote Originally Posted by kioji41 View Post
    what editor is that?
    Moderator
    PremierD's Avatar
    Jun 2009
    This one mate .....
  11. The Following User Says Thank You to PremierD For This Useful Post:
    Kev10001 (27th June, 2014)
  12. #11
    gee thanks for that is there a calculation for the Vin number just trying to work it out i see where it goes ect
    i have worked out a few other things like the mileage ect
  13. #12
    uk
    just edit in as it is on the right side of the table ,the asci side with weird charecters.............
    raf.........
  14. #13
    thanks for that
  15. #14
    thanks again for all you help but to get to the bottom of this problem it looks like i have a corrupt file on the eprom (someone else had been at this before me ) so what i am asking is does anyone have a good dump for me to put on this dash i can change the Vin number now i know how i think the odometer data are on the top line i need 85000 km on it
    i already have two files but both are looking corrupt
    many thanks if someone please help
  16. #15
    Timisoara-Romania
    Petrol or Diesel ?
