Using telnet to flash an image,
eraseall gets to 100% the I get ILLEGAL INSTRUCTION
and it goes back to the promt
what could be causing this
Wrong message I suspect. You have to type these instructions to the best of my knowledge with correct spaces. Just cut and paste the instruction though if you are trying to flash/backup an image you shouldnt need to type the message in.
Probably the filename of the actual image doesn't match the filename in your command.
If the command fails at this point, make the changes, i.e. to the filename and reissue the command. DO NOT power the box off because it's already erased the flash and it won't boot. If you do, you'll need to dreamup.
I knew that but had no option had to use dreamup to restore backup,
I dont get it image was named correctly and I cut and pasted the commands
like always,
I know illegal instruction sounds like I typed a bad command but like I said
I cut and pasted the commands, Its put me off telnetting for the mo,
I'll just just use dreamup and network cable
If you're going to use Dreamup anyway, you might as well try the telnet method. If it works, you've flashed it in 2 mins, if it doesn't, well you were going to use Dreamup anyway.![]()
