Results 1 to 4 of 4
    Mar 2011
    EU
    Default Golf 7 cluster Error
    I have a problem with Golf 7 GTD cluster VDO year 2013:
    10485826: Internal control module memory check sum error
    B2000 41 009 general checksum failure.
    On the screen : "cluster failure, go workshop"
    It happened after flat battery.
    Can I erase dtc manualy in eprom, It will work ?
    thx
    diagtech2000's Avatar
    Jul 2013
    North of England
    im guessing you've tried erasing it with different scanners? good ones ideally
    Please hit thanks if this helped you!
  3. The Following User Says Thank You to diagtech2000 For This Useful Post:
    Ocin (13th November, 2020)
    Mar 2011
    EU
    Of course mate, I tried with vcds, actia multidiag.
    Jul 2013
    North of England
    ok try posting dump, but maybe try reflashing with odis
  6. The Following User Says Thank You to diagtech2000 For This Useful Post:
    Ocin (2nd January, 2021)
