Results 1 to 11 of 11
    Aug 2010
    Exclamation Alfa EDC16C39 2,4 tun agr DPD off
    Need stage one remapping stage one with DPF AGR off
    for
    Bosch EDC16C39
    0281012145
    SW : 1037507421
    read with Byteshooter
    can pay for it
    Jan 2013
    POLAND
    This is not full read.. Post full read
    Aug 2010
    ok i have read 256 KB with byteshooter needs 45 min
    not possible only with this
    Jan 2013
    POLAND
    Here is file full..
    DPF EGR OFF
    Disconnect EGR connector
    Thanks and reputation for pass
  5. The Following User Says Thank You to volkswagen1234 For This Useful Post:
    JFR-Tuning (14th November, 2020)
    Jan 2013
    POLAND
    Write file MPPS CMD
  7. The Following User Says Thank You to volkswagen1234 For This Useful Post:
  8. #6
    Aug 2010
    Quote Originally Posted by volkswagen1234 View Post
    Write file MPPS CMD
    or Kess ?
    Thnx a lot
    Pass please
  9. #7
    Aug 2010
    sorry can not sent a private massege your s full
  10. #8
    Gita's Avatar
    dt.tuning.gita@*****.com
    DPF EGR OFF
    write with Byteshooter
    will be OK
  11. The Following User Says Thank You to Gita For This Useful Post:
    JFR-Tuning (3rd December, 2020)
  12. #9
    Aug 2010
    Quote Originally Posted by Gita View Post
    DPF EGR OFF
    will be OK
    See ist later . Other file from m8 volkswygen1234 Not work
  13. #10
    Aug 2010
    I will Test ist today
  14. #11
    May 2020
    tot557545@gmail.com
    JFR-Tuning
    Hello if you need it I have worked solution ... rep + thnx button press
