Results 1 to 12 of 12
    armpower's Avatar
    Jun 2009
    Italy
    Default Freelander TD4 fault, help
    Hallo friends
    I've a problem with Land Rover Freelander year 2001, td4 engine.
    The car during long trips on highway at mid-high speed (140-150 Kmh)
    develope a strange fault.
    The car start to loss power and the speed go down.
    In ecu memory there is a undocumented DTC P1470.
    I've two scan tools Launch and Texa by the way all of them read a P1470 Dtc without any info.
    Have you an Idea what is the explanation of DTC P1470 ?
    Anyone have a Testbook T4 and a list of Land Rover DTC'?
    Help appreciated.
    Thank you very much
    P1470 = loss of turbo boost pressure
    check for burst pipe or faulty sensor
    electromech's Avatar
    Behind a large rock
    This sounds all to familiar could you do me favor m8 and drive vehicle with launch on it and check turbo pressure when fault occurs and pls note the colour of exh smoke too P1470 variable intake fault (variable turbo on that particular vehicle) if you want get the info back to me and I could guide you in the right diretion but if you confident with the vehicle bang on M8
    Intercooler pipes go soft because of oil leaks so check all hoses. Do you hear a whistle when the turbo spins up??
    armpower's Avatar
    Jun 2009
    Italy
    Thank you to all.
    I suspected a turbo loss, and checked hose pipes (replaced two hoses, one with small crack), replaced pressure sensor and checked all pneumatic hoses of turbo' variable geometry.
    Today i'll check more accurately intercooler and air hoses.
    Thank you very much.
    can you get your hands on a smoke pro?
    Newbie boranmutlu's Avatar
    Quote Originally Posted by armpower View Post
    Hallo friends
    Help appreciated.
    Thank you very much
    Your error history looks like a fuel pressure error.
    Near right rear wheel of your vehicle there is fuel filter and fuel pump. please measure fuel pressure. It must be at least 2bar while engine is running around 3000rpm.
    You may measure fuel pressure from pipes at left side of engine room. there is a fuel pressure sensor and its pipe connections.
    There is one more thing about this guess. If your problem really from fuel pressure decrease there must be engine fault lamp while loosing power at high speeds.
    Meat-Head's Avatar
    yes fuel pump rhs wheel arch, do fail
    might be under the hood next to batery
    under inlet manifold check the breather pipe hasn't got blocked up
    lots of oil smoke at 20mph
    armpower's Avatar
    Jun 2009
    Italy
    Thank to all.
    This car have two fuel pumps.Some times ago i've replaced the two fuel pumps and filter.
    I've replaced a couple of months ago also Mass air sensor.
    When the fuel pump error go mad, usually there is a specific dtc, regarding fuel pressure too low.This is not the case.
    By the way my dtc is undocumeted P1470.
    Now i've re-checked all the hoses, also pneumatic hoses (egr and
    turbo variable geometry control solenoid).
    I'm focused mainly in a fault in this area (egr and pressure geometry control solenoid).
    I'm not be able to repeat the fault just to check what happens.
    Customer told me, when he drove the TD4 on the highway the fault appears.The cars slow down and go in limp mode.Dtc 1470.
    In the last weeks also (he told me) develope black smoke during cold start.
    Monday i'll replace the pressure geometry control solenoid and re-test the car.
    Thank you very much for your help guys.
    Meat-Head's Avatar
    start.
    if any broken sorry can't read,
    VNT15-Turbo
    Surging of engine - MG-Rover.org Forums
    MG ZT / Rover 75 - VIS Valve Motor: How to? - MG-Rover.org Forums
    Land Rover Repair: Fault code P1470 & P1472, land rover freelander, 2002 land rover <b style="color:black;background-color:#a0ffff">freelander</b>
    Ashraf6119's Avatar
    UK
    P1470 Varable intake balance valve - always open
    Land Rover Repair: Fault code P1470 & P1472, land rover freelander, 2002 land rover freelander
    Hope This Helps
    Ash
    armpower's Avatar
    Jun 2009
    Italy
    Hallo friends
    Thank you for your support.
    I've replaced the VGT solenoid, Land Rover Part. STC4198.
    Now the car works well without any other error.
    So the correct route (i think) to detect DTC P1470 is:
    Check all vacumm hoses to egr and vgt solenoid.
    Check the integrity of vacumm accumulator near the engine.
    The turbo' variable geometry must move free without any assle.
    The vgt pneumatic actuator must be work.
    Check the pressure sensor on the mainfold.
    Check egr and vgt solenoid with a vacumm pump and check with a scope the presence of main signal from ecu to solenoids.
    Hope this help.
    Bye bye
