Best ECU tool Opel / Fiat 1.3 Marelli ECU without opening
Results 1 to 5 of 5
    Default Best ECU tool Opel / Fiat 1.3 Marelli ECU without opening
    For Magnetti Marelli ECU´s of engine 1.3 diesel Fiat, Opel / Vauxhall.
    I normally open these ECU`s and make BDM to read and write exterior Flash, interior Flash and eeprom.
    Inside this ECU is MPC5XX
    Is there any ECU tool able to read / write eflash, iflash and eeprom by OBD ? Without open ECU...
    Thanks for your help.
    Aug 2015
    ioterminal maybe
  3. The Following User Says Thank You to dtip For This Useful Post:
    aqua_life (18th November, 2020)
    Jun 2009
    read eprom with mpps v18
    find the pine
    reset ecu, program ecu with OP-COM
    Yes, I know but to program ECU with OP-Com you need vehicle.
    I do much of these ECU´s.
    I want to full clone ECU without open it even if part number is different, but off course same hardware.
    Do you think IO Terminal can do this ? Someone tested ?
    racin-snake's Avatar
    Jun 2009
    IOTERMINAL OR MPPS V18 bench read write EEPROM and MICRO would do these
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
  7. The Following 2 Users Say Thank You to racin-snake For This Useful Post:
    aqua_life (19th November, 2020), kamen4 faca (2nd December, 2020)
