Hello
I'm in need of a password for this laptop to enable boot from cd-rom. Can anyone help me with this? Cant find anything online
Model NO. - CF-52REN76Q2
Serial NO. - 1ETCA12304
Thanks in advance
Hello
Thanks in advance
try this code Bro
3maec37f1v
press thanks and rep if i helped you
OR YOU CAN TRY
Bios password cannot be removed by just reseating the cmos battery. You might need to short the board to reset the bios password. Please take not that this is a critical job you need technical expertise in doing this.
Follow these steps:
Remove Laptop Battery
Remove Memory Cover
Spread spring clips to outside and
pull out RAM memory
Remove clear vinyl label opposite RAM memory slots
In the upper left corner you will see JOPEN1 with a white silkscreen square
Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4"post connecting the motherboard to the laptop case and hold it for 25 -30 seconds. Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Then hit F10 key
HaynesPro online 2024 + AC 2022.02a available, message for where to get them!
