MB Sprinter 903, Tachograph removal
Results 1 to 4 of 4
    Nov 2020
    Finland
    Question MB Sprinter 903, Tachograph removal
    Hey all!
    I am trying to remove the tachgraph from my 2004 Sprinter. (Kienzle A0014460333)
    If I just unplug it, the odometer goes to 0 km and the speedometer doesn't work.
    I was told that I should take off the meters, solder off the component 93c66 from behind the meters
    and put it to a eeprom reader.
    I should change the value 64 from row 2 to value 20.
    In addition I should insert back the kilometers, otherwise it goes to 0
    - this apparently needs a separate program to be done right...?
    Does this sound right to you? Can you help me with a bit more specific instructions?
    I know what eeprom is, I know how to find the component and do soldering,
    I've watched how to use hex editor to modify data, but I am not sure what to do
    exactly with the data and how to get the kilometers in it.
    I am newbie on the field. but eager to learn!!
    Thank you for your help in advance!
    - Riq
    Cllau's Avatar
    Mar 2017
    where friends need me
    189
    just change the value on the hex mentioned above and mileage will show up.......
    Nov 2020
    Finland
    Thanks for lending a hand! Is it really simple as that though? Do you think "changing value 64 from row 2 to value 20" is enough or is there something more I have to do to disconnect the tachograph properly?
    In some other thread people were saying that there are multiple values in the coding that should be changed..? People were sharing a whole dump to fix this...
    rdu04's Avatar
    Summer Crete
    123
    hello
    put dump eeprom here
