please see this one?
Hi and merry christmas to all.
Im a bit confused of how to read a bcm from a 2009 range rover sport.
I need to change vin and mileage as is a scrapyard one, i have the keys to go with it so dont need to touch the immo.
I heard that the vin is stored in two places?
Can someone help with a step by step with a connection diagram either for xprog or carprog clones?
this is a connection for VVDI prog, I recommend reading with VVDI prog
Immo its fine the bcm came with the keys, and worked fine until i loaded the right sw on the system( at least sdd jlr says the key its ok ,lock and unlock, and that problem is not security, checks green in all but says the bcm have the wrong vin number, and it shows the different numbers)
If its no other option , will have to get that vvdi, or maybe its a company which do it, or may i can get something with the pickit, may will need to learn some prohramming skills, but its doable i believe
Just another question, it looks like the flash memory its protected in this ones, so it cant be read with a pickit, but it can be erased and rewrited with this, so there is some dumps around in this forum, are they all the same or they include de immo info?
Saying that because if they only differ in VIN number can i take one of them just change the vin and use it or that will also erase the immo?
