I found three eeprom dump from 13267550 UT Instrument Opel Astra H OPC and i think it maybe works. Now, i need check it. This is the next proof.
i need the IPC dump eeprom from this IPC number:
13309008 (COD. YJ)
if someone have this eeprom dump, can share? i need this dump to check th OPC needle sweep but i have the VXR and change the IPC odometer to miles.
Seem the VXR and the OPC have a different value and change the odometer mileage.
Solved
for Kilometers and scan OPC is 08
88 enables the NS VXR and changes the odometer to miles
08 enables the NS OPC and the odometer stay in Kilometers
I tested this now and its OK
A0 is in miles
20 is in kilometers
Tested in IPC SW 7.655
I need to check it in my car IPC, but looks good. looks good and in kilometers haha.
Hi, can you send me your OPC IPC dump, i want to find needle sweep adress? xxxxxxxxxxxxx
In which adress modified in EEPROM for needle sweep?
Would you mind sensing me the dump from this same Eeprom? I cannot find one for YJ out there, I’d really appreciate it and it would help me out a lot!
My email is xxxxxxxxxx
Kind Regards,
Roy
Can you please write instructions
