Attach your files
I tried to turn off the EGR on the Shenic EDC16C3. ADS EGR REMOVER created the file but when loaded into Flash memory. The car is not switched off EGR. When I compared the ORIGINAL and EGR Off files. They make no difference. Does anyone know what the problem is? And if someone might have some other calculator that makes the correct file I would be grateful. Is there a possibility that the original file is not correct. It was read with a KTAG device BDM press.
Attach your files
Eight bytes walk into a bar. The bartender asks, “Can I get you anything?”
“Yes,” reply the bytes. “Make us a double.”
Here is your file
RadovanPetkovic (26th November, 2020)
Thanks for sharing the File. But that file is exactly the same as the original. And exactly the same as the one I made with the ADS EGR REMOVER calculator. When all these files are compared in the BIN editor, they are exactly the same files
here is egr file off
Thanks to everyone but all these files are the same as the original. There is no difference in any BIT. Calculators always do the same. They don't really change anything in the original file ....
I will try all these files and report the results, but I don't think there will be a difference because there are none in the files either
already there are many different
My fault. The editor had a very pale, inconspicuous color to mark the differences. Since it is a large file when the content is listed, no differences are seen. I changed the color to dark blue which is far more noticeable.
We test it on the car and report the results. Many thanks to all the colleagues who helped me
I want to correct that there are differences in my sent files as well. Now the differences are more noticeable so I find them myself. But still with these files the car did not clear the DTC error.
When someone learns to work manually and does not use software searches. There is a search that automatically switches the pointer to differences. And not to be searched by viewing the entire file which is very large
Epilogue: After loading the file into the ECU. When turning the EGR valve connector on and off. The car does not see such changes, but always reports a DTC error DF209 or P1486. The only solution was to clear the DTC error with the DTC Remover Calculator
DF codes are not same with your P codes. I write you in pm.
Pozdrav
