Results 1 to 2 of 2
    Aug 2010
    Lightbulb Abritus AVDI W202 EZS BENCHMARK TESTING
    Hi m8,
    Today I made a negative discovery while trying to read an EZS from a W202 on Bench. This used in the passt to work, you just had to put a key in the ezs, is no longer possible today.
    the box with relay must now be used. ABRITES offers NO adapter. you have to go into the plug with needles, which is obviously not good for this one.
    otherwise I made keys with the CGDI AND FAST ADAPTER, so I didn't notice it.
    But the CGDI can’t only make ECUs vergin, not Peer them with Ezs.
    does any m8 know to use the FAST ADAPTER at AVDI?
    Any one knows whether the dump one with the CGDI had read with the AVDI can be used to learn an ECU with Abrites?
    Thnx for any help
    Aug 2010
    Solved
    For everybody have Same Problem to Connection on bench i have a working Solution
    the picture in the Manuel from abritus is shit. U must use K-line Pin 1 and LIN 15 on OBD connector that work. No relay.
