Results 1 to 6 of 6
    Nov 2016
    Default Fiat 500 airbag ecu
    Hi i have an airbag ecu with no communication, not sure if the car had a crash or not, there is someone who may have a pinout to connect xprog to it?
    It is a siemens 51782985
    Looks like the chip i have to read is the 5320?
    Also, anyone knows if its compatibilty wit other fiat modules same brand slightly different code like 5wk44108?
    Mar 2016
    You need to read this "5320" as 95320 and post here dump to see if there is a crash or not
    Nov 2016
    Hi, i will, however i looked lots around but cant find what pin connect to what pin on xprog, which is the tool i have available.
    It came with a small board it looks will fit the 95320 soldered on it, but no socket to plug on the xprog
    Nov 2016
    Default Question
    Anyone who know?
    Nov 2016
    Just when i thought i fried the 95320 trying to connect it to xprog, i have got some readings, i presume cant use anymore this eeprom, but a new chip with a clear dump will do.
    Anybody who can try to check if this dump have crashes logged and clear them?
    Nov 2016
    Here is the dump
