Results 1 to 7 of 7
    Mar 2016
    Default CAS 2 Vin Change with checksum.
    Hi, Guys.
    something i am doing wrong.
    i have flashed the CAS2 with Winkfp but only short vin changes and not long vin.
    I have tried most tools to change the long vin but it just doesn't accept it. even though the checksum is correct (i think)
    i have then Manually calculated the checksum and modified it in hex editor but its not accepting it and the vin is showing "yyyyyyyyyyyyyyyyy" which is the same when vin is all ff in hex
    i have calculated my checksum for WBAVC32030VA31631 to be "00" and used these hex values
    57 42 41 56 43 33 32 30 33 30 56 41 33 31 36 33 31
    can anyone look over it and tell me where im going wrong.
    i don't mind donating some money for your time. since its only cas2 that has this checksum problem.
    please note i have tried all most all the basic applications, AVDI dumptool, bmw ISN, + all the other ones and it shows correctly in them but when i plug it in the car it doesn't accept it and shows it as blank or yyyy
    thank you.
    droidwayne65's Avatar
    Aug 2015
    North America
    VIN displays just fine in Tango and BMW ISN.
    <---- Coin of the Realm.
    Mar 2016
    Quote Originally Posted by droidwayne65 View Post
    that's what doesn't make sense to me
    kiszka's Avatar
    Quote Originally Posted by henal View Post
    Hi, Guys.
    thank you.
    this cas does not have a long isn
    https://mega.nz/file/R6hS3D5I
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  5. The Following User Says Thank You to kiszka For This Useful Post:
    henal (7th December, 2020)
    Mar 2016
    will try and report.
    Mar 2016
    Quote Originally Posted by kiszka View Post
    hi, you file worked, any help in how you calculate your checksum ?
    Moderator
    PremierD's Avatar
    Jun 2009
    Magic ....
    Checksum 04....?
