yes, eeprom is immo offHi folks.
I have a case and i want you expertise. The car is a Peugeot 207 HDI 1.6 with Bosch ecu number 0281013868. The car was diagnosed having faulty ecu. The had the ecu sent to a repair lab and they said they can't repair it. The lab sends back the old ecu(with the eeprom removed) + a used ecu. So far so good .
The problems is that the new ecu has a dozen of faults regarding DPF (The car was without dpf or with dpf off) , and way lower power. So my task was to read the flash with BDM FGTech from the old ecu and write it to the new(used) ecu. The thing is that when i putted the ecu on car i had a no start situation with P1615 fault. I reading it again and see that the eeprom contents was altered . Just for kicks then , i write a new 95160 with the programmer and soldering it on old faulty ecu. No start again and the same P1615. I read it ,and the contents are different again! What the Hell!? .
Ended to BDM write the used ecu flash+e2p to have the car start. What is going on? Am i doing something wrong?
P.S. The e2p seems to be immo off.
Thank you !
