Check and report back
chiaro....
[SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
@joker01, thanks but it's not working, the diagnostic suitcase delphi tells me:
B0112, B0111, B0114,B0115
Describe errors ? Clear crash not equal fix bad elements, you should change bad elements or join resistors 2,2ohm and clear errors ...
Best regards.
Dragon
Hello, I bought this airbag calculator on occasion, my car has no side airbag and no sensor. It is possible that you will download it because I do not have the fiat case
Hi khassani
If you don't want to replace the SRS, do as dragon100 wrote, put 4 resistors and cheat the SRS.
hi friend,
I understood with the resistors, but the original SRS I no longer have it.
I need to download the new one for the options.
someone has a solution, please ?
