here.....................
I need help for Volvo V50 2007 year.
I need to sync ECU+CEM.
I don't want for free, but I can't find solution. I find software in Google (which made by codecard) but that software ceased, I can't download it.
If you know software or online sync or you can help me, please help me.
I read CEM EEP from MC9S12XDT256 1L15Y.
I read ECU EEP (SID803A) with smok.
I attached CEM_EEP, ECU_EEP and ABS Hardware Serial Number.
Thank you very much!
need help
now my goal is to buy xp-005
who will help?
Thank you very much rafal! File is good, the car works!
How much do I owe?
Do you know any program which do it this and I can buy?
immokill thank you too, I see the file same as rafal.
You are professionals!
Have a nice day!
Hello! I have a same problem...
CEM EEP MC9S12XDT256 1L15Y
ECU EEP (SID803A)
Pls help.
Thanks!
here................press buttons
need help
who will help?
Здравейте, аз също имам нужда от помощ, ако е възможно да синхронизирам моя CEM-ECU на Volvo V50.
ABS SN: 000000159834
благодаря
Ciao, ho lo stesso problema..
CEM EEP MC9S12XDT512 1L15Y
ECU EEP (SID803A)
aiutami per favore.
grazie!
Could someone match ecu eeprom with cem data ?
Attached 1l15y cem eeprom read and 95320 ktag read.
ABS serial : 000000196708
SID803A
Thanks in advance !
floflo00& (17th August, 2022)
works perfectly ! Many thanks rafal !
Bonjour puis je avoir de l aide pour la synchronisation du Cem avec ECM je ne sais pas du tout comment faire
Merci d avance pour votre aide
