Maybe........ 5090
Maybe........ 5090
georgedigital (2nd December, 2020)
or..... 0905
I'm waiting for feedback from georgedigital
i will try and report
billakoss (14th March, 2022)
5090 is correct!!!
miroopel (2nd December, 2020)
Urgent question...I have backup micro and eeprom original from edc17c59 ecu and want to write to other same hardware and software ecu.Did someone knows if need to do chk?Read and write both ecus with ktm-100
no one have try before?
Finally solved!I tried it and no need chk.Only mod files...
Try 0905.
Thanks & Rep if i helped.
Regards
Hello to all. I have a similar question. I broken my ecu but I have a full backup. If I found a used ecu with the same hw number, can I write old map and eprom file to new one? I need the pin code of the new ecu?
Hi mates,
I have one 17C59. Can anyone get me pin from these units please?
thanks a lot
Hello try
Original 6735
Donor 1084
<a href="https://www.evc.de/en/check_evc_license.asp?k=JETn6EjRQpeE9y4%2fKKRgkQ%3 d%3d" target="_blank"><img src="https://www.evc.de/common/check_evc_license_image.asp?k=JETn6EjRQpeE9y4%2fKK RgkQ%3d%3d"></a>
alclot (11th May, 2022)
