Results 1 to 9 of 9
    Jun 2017
    Minsk
    Default Toyota Сamry 2019 89170-33750
    Hi. Please help to clear the crash memory Toyota Сamry 2019 89170-33750 MCU R7F701A223
    superjet's Avatar
    Aug 2018
    If you want try this one,not tested.
  3. The Following User Says Thank You to superjet For This Useful Post:
    mrandrerio (2nd December, 2020)
    Jun 2017
    Minsk
    Thank you. I'll check it today.
    Jun 2017
    Minsk
    Hello superjet.
    After deleting the errorB1163 Airbag ecu malfunction 4
    the error is removed, when you restart it again appears
    the error is removed, when you restart it again appearsAfter deleting the error
    superjet's Avatar
    Aug 2018
    write your ori file and check it have or not Airbag ecu malfunction 4 dtc
  7. The Following User Says Thank You to superjet For This Useful Post:
    mrandrerio (5th December, 2020)
  8. #6
    Jun 2017
    Minsk
    the original file was recorded, the error remained
  9. #7
    superjet's Avatar
    Aug 2018
    try this one,same pass
  10. The Following User Says Thank You to superjet For This Useful Post:
    mrandrerio (6th December, 2020)
  11. #8
    Jun 2017
    Minsk
    Thank you. Tomorrow I will do a test and a report
  12. #9
    Ukraine
    Mrandrerio check PM.
  13. The Following User Says Thank You to Vladimir.zheurov For This Useful Post:
    mrandrerio (7th December, 2020)
