Results 1 to 3 of 3
    Member xlinuxasx's Avatar
    Jul 2012
    Default Passat b6 aux heater
    Hello, i have passat b6 2.0tdi with fuel powered webasto aux heater. It stopped to work now. I even cant start it with vcds basic settings to test it.
    There is no fault codes but in live parameters i see aux heater coolant g18 sensor temperature is 138c. Maybe this is the problem?
    Mar 2013
    Yes this is the problem , aux heater will not start with temp 138c , G18 sensor is inside aux heater you must check it or change
  3. The Following User Says Thank You to neopl1 For This Useful Post:
    xlinuxasx (2nd December, 2020)
    Jul 2012
    Ok, thank you for info!
