We've borrowed an Opcom from a friend. It is running firmware version 1.95 and the software being run is 120309a-131223d (Although it only shows as 120309a from within the software itself).
We have replaced the Diesel Particulate Filter (DPF) in a Meriva B (2010) with engine code A13 DTC.
I believe there should be an option under Engine, Programming, Diesel Particulate Filter, Replace - but we are not seeing this option.
Is this because of the firmware version, software version, or this just isn't available with our engine.
Any help and guidance would be appreciated.
Thanks in advance
