Results 1 to 2 of 2
    dd1's Avatar
    Aug 2014
    Default Mercedes Benz DPF, NOX, egr DELETE
    Hi to all DK members. i an new to this DPF, EGR DELETE. my main concern is the mbz sprinters, ml and gl models. what tools or programmers are required? to read the modules, and software to delete them. thank you all again. is the mbz sprinters, ml and gl models. what tools or programmers are required? to read the modules, and software to delete them. thank you all again.
    Johnsy1998's Avatar
    Oct 2019
    United Kingdom
    You can use a variety of tools too read ECU data, KESS V2, MPPS, GALLETTO, I personally use KESS V2 genuine, supports many protocols and 24hr support including VR readings which clone will not do.
    Also EGR/DPF/NOX ETC, manual solutions using Winols or something similar will always be best solution to ensure proper removal etc.
