Results 1 to 5 of 5
    Jan 2018
    south africa
    Default landrover freelander immo off
    hi pleasse need assistance freelander 1999 immo off bosch 0281001420 right 93c46 attached the vehicle got a lucas remote indicators flashing no crank original ecu was stolen thanks in advance
    rafal's Avatar
    UK - PL
    need help
    now my goal is to buy xp-005
    who will help?
    Jan 2018
    south africa
    thanks i did try that solution wire 45 yellow and red cut at ecu also indicators stilll flashing no crank from ignition
    Jan 2018
    south africa
    is there any way too bypass the lucas remote alarm system ?
    Jul 2017
    Remove eeprom near yellow capacitor ( or both) cut pin 45 or disconnect immobox. And connect starter relay black/yellow wire to ground.
    Try and report sir
  6. The Following User Says Thank You to Tanjona For This Useful Post:
    jacques23 (3rd December, 2020)
