Results 1 to 13 of 13
    Dec 2010
    Default help opel display bid unpaired and correct step to pair
    car have broke gid now want mount bid, i attach 2 dump radio original and gid from other car, the correct step is unpaired bid and pair whit radio original pin? thanks for help i'm not sure for my original pin write in name of file
    WALES
    Quote Originally Posted by marcobh5 View Post
    Where is original display dump?
    wbr
  3. The Following 2 Users Say Thank You to shooting For This Useful Post:
    catalinosonesti (5th December, 2020), marcobh5 (5th December, 2020)
    Dec 2010
    it is necessary? it was broken and I must have thrown it away
    WALES
    You need data from it......
    wbr
    Dec 2010
    Ok search in rubbish
    bank's Avatar
    Feb 2017
    Ukraine
    Case 1.
    1. Read code from radio and BID
    2. Reset radio by dump correction
    3. Pair with BID using code from BID (8085)
    4. Unpair using code from BID
    5. Pair using code from radio
    Case 2.
    2. Reset BID by dump correction
    3. Unpair using code from radio
    4. Pair using code from radio
  8. The Following User Says Thank You to bank For This Useful Post:
    miroopel (6th December, 2020)
  9. #7
    WALES
    Quote Originally Posted by bank View Post
    Case 1.
    Case 2.
    PIN = 5915 for car..... not 8085
    wbr
  10. The Following User Says Thank You to shooting For This Useful Post:
    Albert G (6th December, 2020)
  11. #8
    Aug 2019
    Bulgaria
    Quote Originally Posted by shooting View Post
    wbr
    bank wrote: 5. Pair using code from radio. Pin radio = pin car
  12. #9
    WALES
    Quote Originally Posted by miroopel View Post
    3. is the incorrect statement
    wbr
  13. #10
    Aug 2019
    Bulgaria
    3. Pair with BID using code from BID (8085) or 3. Unpair using code from radio?
  14. #11
    WALES
    Stop spamming thread with irreverent questions....
    wbr
  15. The Following User Says Thank You to shooting For This Useful Post:
    Crasftsman (6th December, 2020)
  16. #12
    Dec 2010
    here dump original display
  17. #13
    WALES
    This is a bad read, can you check your settings and try again
    wbr
