mzhmzood2021 (18th August, 2022)
test and report
anarvaezing (25th April, 2022), bonux (6th December, 2020), entermobile (27th December, 2023), icejack (12th April, 2024)
works, just need to recalibrate sas but its ok, thanks!
howzit need my dump to be repaired please toyota prado with 93c66b 89245-74010 angle sensor
'If I helped, please click Thanks +Reputation.. !'
kork12345 (15th July, 2022)
kork12345 (15th July, 2022), rtbdiagnostic (13th May, 2021)
password please for
oyota steering angle sensor 89245-74010,
c66b ori fault_fix.rar
Thank you
READ YOUR 93C66
What might have caused that DTC in the first place. Was the steering column replaced or just the value went outside limits and caused that fault?
Did the car skid or did it suffer damage from a crash?
Finding a fix without finding the root cause keeps my mind running
Hi try and report
Pass in PM
If I helped, please use reputation+thanks button.
I have 2013 Prius Plug-in with Steering angle sensor problem, need to clear 93c66.
Thank you in advance.
Please send password.Thank you.
Please help to remove the error from sas 89245-74010 c1433
Re read data with selection of 93C66X16
thanks and regards
We make A
Living by
What we get,
but we make a
life by
What we give.
-Winston Churchill
swap bit 89245-74010 93c66
