Results 1 to 14 of 14
Hybrid View
    rob h's Avatar
    May 2011
    Default isn to cas3++ Mini
    Hello guys,
    Mini 2008 with cas3++ akl.
    And no ecu.
    So i now have a new mevd172 ecu, with isn.
    I tried writing isn into org cas3++, vvdi2 stated not supported.
    Can someone write this isn into the cas3++?
    Or is that not possible, because it is a akl cas3++?
    Thanks guys
    Isn to cas3.rar
    Aug 2015
    Germany
    not possible without old key or isn...
  3. The Following User Says Thank You to Chriz123 For This Useful Post:
    rob h (7th December, 2020)
    rob h's Avatar
    May 2011
    The remote still works,
    But no transponder signal.
    I replaced the coil.
    No improvemend.
    I Will look for another key, and swapp eeprom.
    Maybe that Will work.
    KriptoKey's Avatar
    Feb 2012
    Transmission is 6HP or is it 8HP?
    I wonder if I give you a file with your ISN, can you program a new key?
    Let me know
    Cheers
  6. The Following User Says Thank You to KriptoKey For This Useful Post:
  7. #5
    fixanycar's Avatar
    May 2010
    here
    I don't think the key is an issue.
    Renew and rewrite it will be an option.
    Need to write DME isn into cas via OBD while writing a key. Kinda messy for me all the time I do 3++
    Sent from my HD1905 using Tapatalk
  8. The Following User Says Thank You to fixanycar For This Useful Post:
  9. #6
    ASCM's Avatar
    Oct 2018
    Can you post cas I'd readed by vvdi 2
    Sent from my SM-J415F using Tapatalk
  10. The Following User Says Thank You to ASCM For This Useful Post:
  11. #7
    Gavra's Avatar
    Jul 2010
    Belgrade/Melbourne
    Downgrade, write ISN, upgrade, take money
    Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
  12. The Following User Says Thank You to Gavra For This Useful Post:
  13. #8
    ASCM's Avatar
    Oct 2018
    Maybe vvdi 2 don't support this
    ID FW for downgrade
  14. The Following User Says Thank You to ASCM For This Useful Post:
  15. #9
    Aug 2015
    Germany
    you are sayin AKL but the remote is working?!
    did you make a key or do you have an old key ?!
  16. The Following User Says Thank You to Chriz123 For This Useful Post:
  17. #10
    rob h's Avatar
    May 2011
    It is a manual gearbox.
    The key belonged to the org car, cas3++. So yes it is a old key.
    I called it akl, because it did not start. Only open and close by remote
    I replaced the transponder antenna coil, and reflowed the pcf.
    That did not work.
    I did not downgrade, and then tried writing isn.
    Only tried write isn to cas3++ as is.
    I will try that.
    flash version is
    9389115
    I dont have a cas3 key oem.
    Could i transfer the pcf to a cas4 smart key?
    I have seen some retrofit keys.
    This might bring the key to live.
  18. #11
    pepi's Avatar
    Jan 2010
    Try to find used key , that will be best option . You cant transfer on CAS4 smart key.
  19. The Following User Says Thank You to pepi For This Useful Post:
  20. #12
    Aug 2015
    Germany
    pls stop tryin something when you dont have any idea what are doing
    post untouched cas eeprom (i guess post1 file)
    read and post key psw / page3 cfg, if you didnt destroyed the key (maybe need place back old coil) or better read second key if aviable
  21. #13
    rob h's Avatar
    May 2011
    I have just transfered the pcf7945 to a chinese cas4 key.
    Now i have the org isn from the key.
    I will try to change the isn tommorow.
    The eeprom, i posted is untouched.
    And the isn is A10C0E794A62E11A2DC4DE50CDD6479E
    Thanks guys
  22. #14
    Aug 2015
    Germany
    why so complicated
    here youre file pass pm
  23. The Following User Says Thank You to Chriz123 For This Useful Post:
    rob h (8th December, 2020)
